Fuel filter?...not fuel pump sock.
If by chance you do get yours replaced post up some pics to prove the filter does exist on our cars here in N. America.
here they also replace it once every few years.
it's a huge job involves removing seats and all rear interior plastic.
i think even soft top should be removed - but somehow they manage to avoid that.
according to service manual if there a is a fuel pressure drop - fuel filter is one of te things to be replaced.
just to add to this.. I recently purchased the replacement fuel filter assembly from Honda and the filter may be slightly different than what came with the car.. not sure why this is.. but the wire harness that connects from the pump to the housing + ground is slightly different. Instead of 1 ground, there are 2 grounds that must be mounted to the housing. The filter/insides could possibly be different as well, but there is no way to tell without dissecting it.
