Fuel Cut Off Switch (tried search)
^ I've never looked into it or even heard of a setup. You have any type of examples. And to me if it's going to save my car from being stolen I'd be willing to go through some hassle. Not being lazy has to be one of them. I'm going to talk to an electric guru buddy and see what he comes up with. Knowing him I could probably pay him for a pass code ignition system type of thing.
Grade 8 bolts has less shear strength than regular bolts. Correct me of I'm wrong but wouldn't shear strength be more important in this situation than tensile strength?
Fuel cutoff switches are easily & quickly bypassed by experienced thieves; they've been played out.
Instead, kill the ground on the PGM-FI main relay and relocate it. In addition to this, but not in itself, a starter cut would also be good.
Originally Posted by jetboater' timestamp='1371437666' post='22612487
If you use any seat bolts other than the OEM or Kodokan's seat locks, make sure they are grade 8 or higher.
Keeping the seats attached to the car in case of a accident is a critical safety factor---this is not an area to cheap out on....
I think you're right in that shear strength is more important. Going by this chart, grade 8 has twice the shear strength of grade 2....
http://nucor-fastener.com/Files/PDFs...r_Strength.pdf
it seems the industry standard calculation is that shear strength is .6 of tensile strength and the tensile strength of grade 8 bolts is substantially higher than grade 2.
I'm not an engineer so I really can't debate the details of this....if I'm incorrect, please clarify.
thanks!
like stated above, its basically a starter cut.
Originally Posted by pa9k' timestamp='1371467490' post='22612879
[quote name='jetboater' timestamp='1371437666' post='22612487']
thanks!
[/quote]
Just spoke with our engineer, and you sir are correct.
Andre
02-26-2001 07:09 PM
