front strut bar instalation
hello,
new here on s2ki!!!
i just bought a front strut bar and had a little trouble installing it...When installing the strut bar there is this wire that gets in the way on the drivers side. I cant find a way around it, does any1 know if its ok to disconnect that?? can you even disconnect it?? also, will the strut bar work correctly if i furbish it a little??
any help would be greatly appreciated!!!!
new here on s2ki!!!
it was a pain for me to do, but you just have to work the strut under it... get that side of the strut into place before the opposite side... it takes a bit of effort, but you don't have to disconnect it...
ok so the girth of the connecting arms of the strut bar are a bit girthy...does any1 kno if its safe to take the wire leading out from the auxillary fuse box?
how do you guys install ur front strutson your AP1s?
any suggestions will be helpful
it'S2klean
04-08-2011 09:01 PM
