Front Spoiler Removal
I spun out and damaged my front spoiler, how do I get it off while I'm waiting for the replacement to arrive? How many attaching points are there? Where are they located? Is there anything trick about this?
Thanks
Thanks
Start at each wheel well. You will find that the part that wraps around is attached by a screw. Remove those screws. Then look underneath the lip and you will see some bolts that attach the lip to the undertray. You only need to remove the ones that hold the lip on. Not all the bolts on the undertray are used for this purpose.
