Front/Rear emblems
The one on the left is for the front and the one on the right is for the rear. The front one has two "washer" type fasteners that attach to the pegs to secure the badge.
Instead of using dental floss, use fishing line as the dental floss will keep breaking on you.
The front and rear badges are very easy to do, but the side emblems take a little more effort to remove the old adhesive. You also need to use some adhesive remover to facilitate the removal of the old adhesive.
If you check Rick's site, he has detailed instructions for removing the front and rear badges. In addition, handa-accessories.com has instructions for removing and installing the side emblems.
yeah not to mention the "pins" on the back of both of them are obviously different settings. that should make it fairly obvious once you get the old badges off.
