Front jacking point
Originally Posted by GPW AP2,Mar 16 2010, 08:33 AM
I was researching a new jack a while back and found a site that measured the heights of those jacks. Neither of those jacks will reach the S2K front jack point without something being put under the front wheels. Mine is even worse now with an OEM front lip and a one or so inch drop.
John
John
For oil changes you only need to jack up the passenger front side jack point using the OEM jack. I use the floor jack in the front center point when I need place jackstands for other jobs.
Just in case anyone is interested in the jack measurements I was talking about. I looked back in my email archives and I found it. The site is a corvette website and the link is below.The center of the front jack point is 29 inches back from the front lip and the lip has 4 inches clearance from the floor. I cant remember if those measurements are post drop or not, though I only have a 1 or so inch drop. Someone may need to confirm that.
I also looked into those ramps, though by the measurements I think they would hit the air deflectors that are in front of the front wheels. I would love to know if they clear, so I can buy a set! If anyone knows please post it up!
http://forums.corvetteforum.com/c6-corvett...ac-dk13hlq.html
John
John
Originally Posted by aresk3b,Mar 16 2010, 04:28 PM
The front jacking point I believe is intended to raise the vehicle while on the alignment machine to service/adj terminals etc. and not to be used with floor jacks.
So... The "Jack point" is not intended for a Jack or to Jack up the car?
I was also told the fuel should be sprayed into the trunk opposed to the gas cap as the gas cap is for adding fuel additives not fuel, the headlight switch should never be moved foward to turn your lights on as this left stick is your signal controller only, as well as you should un plug your "brake" lights unless your going on brake at work.
Originally Posted by bouford,Mar 16 2010, 12:56 PM
Originally Posted by S2K Medic,Mar 16 2010, 01:42 PM
I love funny statements as such.
I said that the front central jack point should be used for raise the car while on the alignment machine... and that on the machine is and hydraulic jack too.
a normal floor jack cannot be used, you need a race/Low Profile floor jack to access that point.
FWIW I have the HF jack mentioned above. Driving one tire onto a couple boards is enough to get access to the front jack point. The jack works fine, though the set screw for the handle is right on top and kills about 1/2 inch of clearance which sucks.
Also, If you're gonna jack up just one side for an oil change, wouldn't you do the driver's side? Cause if you do the passenger side, some oil will still stay in the pan.
And you do use a stand after you use the OEM jack, correct?
