Front BS kit="heavy" steering and EPS light?!?
I recently lowered the s2k. I installed the megan front bump steer kit to help align the inner tie rods after being lowered. The question is there a minimum height you need to lower it?
The reason I ask is because I have a modest drop, nothing to crazy. I am assuming the bump steer kit may be putting to extra stress on the inner tie rods and causing my steering rack to act up. By act up I mean the steering can be very heavy at times, similar to losing power steering.
I also had the EPS light come on for a second then go off. Has anyone else heard of a similar issue?
NOTE: none of these problems occured until after the front bump steer kit was installed.
Any help you can provide will be greatly appreciated.
