Friendly Reminder: Cabin Air Filter
Old 04-13-2009, 05:41 PM
  #21
Banned
Daygo S2k's Avatar
JUST A LITTLE TRICK WHEN YOU REPLACE IT....SPRAY SOME OF YOUR FAV. COLOGNE ON IT....
THE LADIES LOVE IT...
Old 04-13-2009, 06:23 PM
  #22
USMCs2k's Avatar
where the hell is this thing the thread shows no pics
Old 04-13-2009, 08:16 PM
  #23
s2kVTAK's Avatar
pop the hood and go to the passenger side. up next the the firewall is the plastic cowling. there is a little tab on the edge of it that says lift or pull or something to that extent. lift that and under there is the filter.
Old 04-13-2009, 08:23 PM
  #24
pdenton's Avatar
just curious, what's the reason/benefit behind changing it? I'm guessing cleaner air being circulated (with the top up) and the A/C probably doesn't have to work quite as hard. It probably also helps the defroster work more efficiently as well?
Old 04-14-2009, 08:59 AM
  #25
S2K Type R's Avatar
Yeah, what you said and it helps reduce some allurgens if you have breathing problems.
Use a flat head screwdriver to gently pry off all the retaining clips before pulling off the cowl or you will lose these little clips all over place and potentiall interfere with your engine mechanics.
rsdub
01-24-2017 01:08 PM
jonner
06-26-2007 02:30 AM
vassosva
06-10-2002 07:40 PM
1Randyc
03-29-2001 09:42 PM
Quick Reply: Friendly Reminder: Cabin Air Filter
