FREE---easy shifting!
Originally Posted by osidis,Dec 12 2010, 03:37 PM
yes synchros are there for a reason. not to be beat to shit. plus it cant hurt. and yes i agree there might be an adjustment needed or something wrong.
Originally Posted by osidis,Dec 12 2010, 09:10 AM
you dont buy an S2000 to be lazy. its a drivers car. double clutching is better for your car anyway, so why wouldnt you do it? Go beat up a nissan if you dont want to double clutch.
You have a starter motor, don't be so lazy push it to start it and just drop it into 2nd and roll.
That's how your comment comes off.
OP - your double clutchin will work but shouldn't be required.
Shifting is three distinct steps. Clutch to floor, pull out and into gear, release clutch. If your hand and foot are moving at the same time you're breaking something.
Originally Posted by JFUSION,Dec 12 2010, 06:00 AM
While that will work there are a few things you should try if you have some extra time. My car is a fair bit older than yours and I got it to shift perfectly with just a few adjustments. Here they are:
Adjusted the clutch to raise the disengagement point by lengthening the clutch rod (simple adjustment), Change the clutch fluid and clean out the clutch MC if dirty, Lube the shifter as per the TSB, Put in fresh Honda MTF2 tranny fluid. I just put on a heavier (skunk2) shift knob which feels even better but the first four items are most important.
https://www.s2ki.com/forums/index.ph...c=192881&st=0&
adjusting the pedal?
Everyone ragging on double clutching is an idiot. I mentioned this before as well. The transmission is designed for high rpm shifts, not low putting around town shifting. Did you guys ever notice that 6-8K shifts feel way better than 2-4 K shifts? The transmission doesnt slow down enough at lower RPM to engage the next gear properly unless you either:
1) DC as the OP mentioned
2) Pause for a split second.
If the naysayers understood manual transmissions, you guys would also know that syncros are like clutches, they wear out. Its not some magical fairy dust item that you can use forever. By pausing or double clutching you can lengthen the lifespan.
Do I double clutch? Not when driving spiritedly (high rpm shifts, shifts like butter) but when I'm putting around town shifting at 3-5K, I do.
Most of you guys who say it shifts fine at low RPMS are either:
1) forcing the shifts & abusing the synchros
2) shifting slowly without realizing it
3)???
A heavier trans fluid might slow down the transmission significantly, which might make it seem like you're getting better low RPM shifts but then higher RPM shifts will feel worse.
3)???
Originally Posted by SgtB,Dec 12 2010, 05:31 PM
His synchro's aren't the problem. The ring teeth are mushroomed. It's downhill from here. If you pull the shifter into the synchro and wait for it to lockup and follow it in, there is no damage. It's when people power shift or don't push the pedal all the way to the floor before pulling it out of gear that kills it.
[QUOTE=buzz944,Dec 12 2010, 07:19 PM] sorry to thread jack,
