Found this in the Oil Pan. Any Ideas?
Old 07-09-2012, 05:57 PM
geared's Avatar
Default Found this in the Oil Pan. Any Ideas?
In the process of swapping my f20 head onto a used f22c block that had some oil starvation and ruined the head. Upon swapping the timing chains I found this little doo dat in the oil pan. I sent a photo to the previous owner who was a mechanic and he is perplexed as well.
What do yall think it is
Old 07-09-2012, 06:02 PM
blasphemy101's Avatar
Pic is broken
Old 07-09-2012, 06:26 PM
geared's Avatar
Old 07-09-2012, 06:33 PM
Slows2k's Avatar
That's the thrust bearing. If your friend is a mechanic he shouldn't be perplexed. I would not be using that shortblock.
Old 07-09-2012, 07:05 PM
hioutput's Avatar
Oh yea trust bearing block is prob sht
Old 07-09-2012, 07:46 PM
RacerXI's Avatar
Pass. Find another block ASAP.
Old 07-09-2012, 08:37 PM
rob-2's Avatar
Get another block.
Old 07-10-2012, 01:28 AM
realblag's Avatar
LMAO....Previous owner isn't much of a mechanic if he doesn't know what that is.
Old 07-10-2012, 08:49 AM
s2klariat's Avatar
With oil starvation the bearings are one of the first things to go in this engine. This engine must've been run pretty low on oil to cause damage like that....
Old 07-11-2012, 09:39 AM
SLracer's Avatar
Yea if oil starvation ruined the head you can bet the entire bottom end was toast well before that
Quick Reply: Found this in the Oil Pan. Any Ideas?
