Flywheel shims required?
I just had my flywheel resurfaced and it needed.045" removed. Shims are available in.025"
Question is, should i go with 2 and be.005 over or go with 1 and be.020 under?
Amazon only has 1 in stock but ill wait for more if i have to. I want to do this right
Any issue with ring gear alignment to starter?
Originally Posted by Charper732
I didn't even think of that, .045" isnt that much though like 1.1mm... I was thinking without the spacer there may be a tad bit less spring pressure from the PP but that was it.
Sent from my SM-G920P using IB AutoGroup
SteveUCI
08-07-2006 07:20 PM
