fluid changes complete, thanks goes to Xviper for tips
hey xviper.
i think i remember in one of your post before that you mentioned that people are starting to fill either the tranny or differential with "extra" fluid, more than what the manual says...
is this true or am i just going crazy?
Originally posted by KLN
hey xviper.
hey xviper.
Also, having taken the diff apart myself, I'm of the belief that overfilling the diff by 50-100 cc could also be beneficial. Since the diff has a vent, if the overfill was detrimental, the excess could easily be puked out. If you don't track the car, this is really not a concern. I don't get too anal about it. I squeeze "a little bit more" beyond the required volume when I do my changes.
I cannot preach doing this since the best procedure is to follow the manual. If you are concerned about warranty, this is the best route to take. Those of us who overfill do so at our own risk and must own up to any consequences. So far, there has been none for me and all has worked well.
Originally posted by xviper
I'm sure RR will tell us what it's for when he sees this.
Now, once again I caution about use of GL-5 in transmissions not designed for it - the sulfurs, especially what are known as "active sulfurs", can be harmful to trannies using yellow metals in them, like bronze.
Here is a link I have had for a while that says it as well as I can, and saves me the retyping - hey Xviper, it's Canadian content!:
http://www.sbcc.ca/tech/lube1.htm
Coraldoc - Absolutely, there's nothing like knowing you did the job and and made sure it was done right. If I learn how to do a couple more things (brake/clutch fluid, brake pads, etc.), the car might never see a mechanic unless something REALLY breaks.
