Fluid changes?
Banned
Fluid changes?
hello
i was wonder if i should bleed the brake and clutch fluid?
my car has 75k miles already and i need to get transmission + rear diff fluid change since its been about 10k from the last one... but would it be good idea to change other fluids as well ? clutch and brake? since my car has high mileage...?
thanks for your help
Originally Posted by kevieeroh,Jun 15 2005, 02:31 AM
hello
Good luck & Drive Safe,
Steve R.
Originally Posted by kevieeroh,Jun 15 2005, 09:57 PM
thanks sir!
today i just bought transmission fluid, brake fluid and rear diff
i should buy the clutch fluid also...
Follow this:
https://www.s2ki.com/forums/index.php?showtopic=118878
and you can't go wrong.
You got it!
Make sure to clean the resovoir out good with a rag. Most likely your clutch fluid is black with lots of crud clinging to the sides. On my car I could see where the moisture in the old fluid was starting to attack the metal inside the bottom of the resovoir.
Originally Posted by kevieeroh,Jun 16 2005, 03:27 AM
so i can use brake fluid that i bought to fill up my clutch fluid??
Also, when you do this, be certain to keep plenty of rags or old newspapers under the brake and clutch master cylinders in case you accidentally spill. Brake fluid is a "first class" paint stripper.
You'll want to wipe up any that gets on the paint, immediately!
Have fun & Be Safe,
Steve R.
Originally Posted by tizbad2k,Jun 16 2005, 09:48 PM
its probably better to rinse with water, instead of wipe, because you might actually wipe off paint as well if you do so.
Your best bet is to prevent contact in the first place, which mean a healthy amount of rags and/or newspaper under the master cylinders to catch any spillage that may occur.
Drive Safe,
Steve R.
