Floor Jack Recommendation
#31
Originally Posted by jasonw,Aug 15 2005, 02:46 PM
Originally Posted by candyass
No, but why does that matter you still need jackstands to get underthe front unless youre an idiot and willing to trust your life to a $.05 o-ring. Jack up one side place jackstand then jack up the center ....takes all of about 2 minutes. Unless you are willing to spend $400 plus on a jack I do not think you will find one that will reach the front center jack point.
#32
Originally Posted by DaveOnLI,Aug 15 2005, 04:31 PM
Can anyone with the Costco jack hit the front center lift point? The jack has a nice low stance for the first 12" but I'm thinking the front center point is more than 12" under the car.
#33
So for the record, has anyone not been able to use the Craftsman jack on the front jacking point of a stock S2000 unassisted?
I'm thinking the Craftsman will be better for having in the garage and the Harbor Freight would be better for transporting...
#34
Originally Posted by boxer6,Jul 19 2005, 06:58 PM
I got the one from sears. It has plastic mat on top of the where it jacks up.
Now I wish I wouldn't have wasted the money I spent on the jack from Kragen 3 years ago! It is full of lube but does not seem to be working right at all!
#35
Originally Posted by thetz99,Jul 9 2005, 03:44 PM
Costco sels a 3.5 ton low lift (3.5 inch to 22 inch) for $76.
But for the price it's worth it.
#36
Originally Posted by blah,Aug 15 2005, 07:03 PM
I have the Costco jack, but can only reach the front central jacking point if I drive the front wheels onto boards.
Cut the front edges on a 45
#38
I found it easier with 4 since you need room to work the lever. Don't forget it's only 1.75" actual per board
And the boards only work if you are jacking from the front and rear center jackpoints. You need to move the ramps to insert the jackstands.
#39
#40
Originally Posted by jasonw,Aug 29 2005, 04:30 PM
So you need more than a 2" ramp to get the jack to clear? Or is it just alot easier with 4"?
