Flickering of instrument panel
#31
Rather than start a new thread (and get the inevitable "use search, Idiot"), I thought I'd just glom onto this one.
I have a 2007, which works fine. Well, except for a very slight flickering of the dash at idle. Higher RPM gets rid of it; no use or non-use of accessories (like A/C) makes any noticeable difference. No CEL (or any codes). Voltage is 14.2. Changing batteries does not get rid of the problem. Tightening the the battery leads does not affect anything.
It's a car fully-prepared for STR autocrossing (meaning, for the purposes of this discussion, re-tuned ECU, using a Hondata). The onset of this slight flickering did not in any way coincide with any tuning.
My first thought, when I saw it and found that the flickering stopped when I revved the engine, was that the alternator is going bad. But the perfect voltage suggests that that isn't the problem.
Any educated thoughts?
Thanks.
Mark
Thanks.
Mark
If you have the capability, externally charge the battery all the way with it disconnected from the car. Then reattach it and see if it still flickers right away, or only after a few minutes/hours of driving.
#32
Here's some good reading of the fix:
https://www.s2ki.com/s2000/topic/387...is-flickering/
https://www.s2ki.com/s2000/topic/108...ier-cheap-fix/
Keep us posted on your progress
#33
Ok, it seems pretty clear that my first step should be to replace the alternator. We have a local guy who does a first rate job of rebuilding alternators, so I'll just bring this in to him for rebuilding.
I'll report back on whether that resolves the issue.
#34
Originally Posted by 124Spider
Ok, it seems pretty clear that my first step should be to replace the alternator. We have a local guy who does a first rate job of rebuilding alternators, so I'll just bring this in to him for rebuilding. I'll report back on whether that resolves the issue.
#35
Originally Posted by slalom44
Rebuilding your alternator will be a lot more expensive than just buying a used alternator. A new rectifier alone is over twice the price of a used alternator.
#36
#37
I put the rebuilt alternator back in, and the flickering is gone (at least for now).
Unless something changes, I am declaring victory.
Thanks for the help!
Mark
Mark
Kiwisama
10-08-2014 12:36 PM
