Flickering dash at idle, already replaced alternator. What now?
I had a slight flicker in my dash at idle, so I went ahead and replaced my alternator in May with a remanufactured Denso 210-0458 for $110. The flicker wasn't completely gone after, but it was better so I let it be.
Now, the flicker is back worse than ever. Should I just assume I got a bad replacement unit and try replacing it again, or is there anything else that needs looking at?
I still have the original alternator, I may go the route of replacing the rectifier and brush holder assembly.
Car on, motor off: no flicker
Motor on, idling: dash flashing like an EDM show. Headlights/ A/C doesn't effect how much it flashes.
Revving in neutral: no change to flashing
Driving over 3000 RPM: very subtle flicker, barely noticeable
May have a bad ground battery cable.
Also, check the grounding points for good, clean, tight contact.
Slow, you mentioned in other threads that a leaking IACV could damage the alternator. Earlier this year I took my IACV apart to clean it, so there's a chance for a leak there but I haven't confirmed. Is fixing that leak just a matter of replacing the hoses/clamps?
Flickering dash is a leaky rectifier in the alternator. They will rebuild them this way as they have no effect on the charging system.
Get a new rectifier and put it in your original alternator.
Better advice could not be given.
New symptoms - the car makes a groaning sound from the front end when idling and electrical accessories are engaged. Here, I alternate between pushing the window switches, turning the wheel, and pushing the top switch so you can hear it.
https://www.youtube.com/watch?v=YpYrHbfB6FY
Thanks for the help so far. I have a new negative battery cable coming (couldn't find a generic that fit so went OEM route). Rectifier will be next.
