Fix for (clutch, heatshield?) Rattle....Please....
Old 06-06-2004, 12:42 PM
morgan's Avatar
9,500 miles and it sounds like a '71 Pinto that needs a tranny....
Old 06-06-2004, 06:25 PM
morgan's Avatar
sorry guys, just venting, thanks for the advice...more input is appreciated....
Old 06-06-2004, 06:42 PM
fly_S2K's Avatar
You said you had an AEM CAI correct? Check if the lower portion of the CAI is touching your sway bar. Mine did that untill I took some insulation wrap and wrapped my sway bar. It wore my AEM CAI a few mm's. Here's a pic .
Old 06-07-2004, 12:53 PM
morgan's Avatar
ttt
morgan's Avatar
CAI is good.
Old 06-07-2004, 06:04 PM
morgan's Avatar
Old 06-07-2004, 07:48 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Try this...Rev the car in first gear, clutch in, not moving. this will eliminate the clutch DISC ONLY.
Old 06-09-2004, 07:45 AM
morgan's Avatar
Old 06-23-2004, 08:55 AM
morgan's Avatar
Still rattles...Must be heatshield, huh?
What about aftermarket clutches, PP, TB, etc...any luck solving this problem with those...
Old 06-23-2004, 08:57 AM
morgan's Avatar
Originally posted by hygiene boy
Also check your header heatshield, push it toward the engine (away from the battery) it will bend slightly away from metal to metal contacts. As the engine rev's it moves and vibrates the heatshield. It did in mine and a few other local guys here. And get under the car and double check the tightness of all the other exhaust heatshields. Good luck!
This worked? Approx. how for do you bend the shield...?
My dealer shows little interest in adressing this problem...he's like, you bought the S2K, now live with it...
Quick Reply: Fix for (clutch, heatshield?) Rattle....Please....
