Fix for (clutch, heatshield?) Rattle....Please....
My car rattles like a POS...I mean an annoying loud rattle, accelerating, decelerating, all in the 3500-4800 rpm range. It's really detracting from my enjoyment of the car. Took to the dealer and he says "clutch rattle, normal..."
this can't be "normal". I can tell the sound of the clutch rattle and I could probably live with that, but I've got buzzing and rattleing from the engine compartment...Hard to localize. it sucks...33K for the car and it sounds like a geo metro...I mean rolling to stop signs I'm embarressed People look at me like "dude, fix your car...."
HELP!
HELP!
You have an 03 so I would be surprised if its the 00-01 TSB rattle but it still could be. Which means that you would need a new clutch installed. If it is the heat shield I would think that you could replicate the rattle at idle but that's not always the case.
Sounds like you need to go to a different dealer, or keep hassling your dealer since your car is still under warrenty.
My dealer was sour on that TSB...Honda had replaced a ton of clutches, only for the rattle to return...
I mean I am seriously considering selling the rattletrap if I can't get to the bottom of this. It's Loud ...
this can't be "normal"....
It got worse after installation of speed X-brace and STB....Spugen exhaust...but i don't think that is the problem...AEM ver 1 CAI...that can't be it...no other mods that I have could affect this noise.....
Just to be certain I'd double check that all of your
X-brace bolts are tight, the STB isn't touching or rubbing on anything, and closly inspect the exhaust for the same thing. I've found many buzzes and rattles from badly fitting exhausts, loose hardware, bent pipes hitting the body, damaged heat shields etc.
Also check your header heatshield, push it toward the engine (away from the battery) it will bend slightly away from metal to metal contacts. As the engine rev's it moves and vibrates the heatshield. It did in mine and a few other local guys here. And get under the car and double check the tightness of all the other exhaust heatshields. Good luck!
I mean I don't even want to drive the fvckin' thing...If I'm on my cell phone in the car, people on the other end of the line are like..."What's that noise....?" (normal)
