FIPK helpp
FIPK helpp
So I have a few vacuum lines I have no idea where they go ill attach pics. Also is there a gap betweeenthe shield and filter. And do you need to drill for the temperature sensor on the ap2 I'm lost
You need to look up the instructions on the manufacturer's PDF. I am no mechanical man but I was able to install mine. Pay close attention to each picture to figure out what goes where...
K&N instruction.
K&N instruction.
K&N instruction.
K&N instruction.
step 14 is very confusing, I dont know where the check valve is
I assume the OP is having issues with how to hook up the coolant line to the throttle body. I can see how it can get confusing without instructions. Just keep in mind you're replacing all the hardlines with the rubber hoses from the kit.
leov36
07-23-2011 09:11 PM
