few questions ... im lost..
OK this is my 1st prob i cant figure out.. sometimes after i shut the car off or sitting at a light it smells like oil burning. had a buddy drive behind me and he said theres no smoke coming out just norm driving... if i dont hit vtec for a long time it will puff some smoke out but only for that one gear...but i just thought it was build up in the cat because its gutted and its blowing it all out... my 2nd prob is that the car started feeling like i broke a motor mount but theres nothing wrong with the motor, trans, and diff mounts... if i hit the gas it kinda jumps like there a broken mount... iv got 80k on the car its almost stock ... intake with catback exhaust (gutted cat) lowering springs, CC 6 puck clutch, and 75shot nitrous with NGK R5671A-8 plugs other then that its stock... is there anything else i should look at ?
*Edit* Should i try a crank vent for the oil prob ? what kinda\brand ?
I would check the motor mounts again. My car was recently doing this, and upon initial inspection, i saw no damages. But while removing my aftermarket motor mounts, I saw that the polyurethane has actually been slightly deformed, causing the bolt not to sit snug at all. Maybe try getting someone to rev your car while you watch the mounts do their thing.
