Ferodo DS2500 Pads Rear Rattle
Hi
Yesterday I fitted some Ferodo DS2500 pads all round to my 2005 S2000. I now have a rattle, at the rear only, over harsh bumps. Should the fitter have kept the OEM clips on the car with the DS2500 brakes in order to prevent rattling, or is this likely to be something else?
Many thanks
Ben
Many thanks
Ben
Which clips do you mean? The stainless steel shims that sit in the brackets or the flat anti-noise ones on the back of the pads? Every honda I've worked on, the bracket shims are required to keep the pad from flopping.
Ben
Originally Posted by Ek9,Jul 26 2006, 05:46 AM
Well, I never used or installed them. My race pads don't have them either. If you used the stainless bracket shims, then they pads aren't going to be flopping. You may want to get your unstaller to check his work.
Thanks
Benh
Yeah, they're pretty obvious. I just went out and looked at mine. There are sheet metal shims between the caliper and the bracket. They stick out 1/4" above the edge of of the bracket. Shiny, thin sheetmetal.
They're OEM.
They're OEM.
They're OEM.
They're OEM.
Thanks for your help anyway
Ben
Pierre S2K
06-13-2003 04:22 AM
