the famous 3rd to 2nd shift
Just yesterday I took a spin on the track, everything was going well until i missed 4th gear and yanked it into 2nd at 9k+. I immediately slammed on the clutch but it was too late. My car shut off and wouldn't start again. I'm pretty sure the head received massive damage, bent valves etc, maybe even hitting the pistons. Now my question is.. for all of you who have encountered the same problem, what have you guys done? rebuild? price? is it just cheaper to buy another engine? if yes, would the f22 interchange with f20? any modifications, aftermarket parts, done while rebuilding?
You can find a good used shortblock for around 3k nowadays. If your car shut down then it definetly received some massive trauma. Well a 9k shift into another gear means you probably hit 11-13k at least. Sorry to hear that.
I would say you would be lucky if the valves are just bent...at that rpm, you probably broke one off. If so then Mike is right...time for a new motor since the current one probably has scored cylinders and mangled head.
But...if it is just a bent valve, you may be able to get away with a head rebuild.
Pull the head and peek inside.
your valves are bent for sure. the block should b ok since u said u immediately disengaged the clutch. but no guarantees. you probably can get away with just rebuilding your head but check your block or get someone 2 check it before you do anything.
It is rare that an s2k breaks valves, but surely it happens.
I have replaced/lapped in new valves and replaced the retainers many times in your situation.
A few light blems on the pistons can be easily sanded smooth by hand with sandpaper.
When I had my money shift the car would still run. we yanked the head and found all 8 intake valves and 4 of the exhaust valves were bent pretty badly. I got lucky, but I wasn't at the rpm level you were. I was around 7k and half shifted back into 2nd.
Originally Posted by RedY2KS2k,Feb 23 2009, 08:09 PM
Nobody can diagnose this for you. Take the engine apart and see what's damaged and how badly.
