Factory 4.10 Gearing
I need to rebuild my factory differential and may need a new 4.10 gear set. However, buying them used can be a problem. So to make sure I get the correct gearing, Id like someone to post up a picture of what the factory gear set looks like. I mainly want to see how many teeth the ring and pinion have. I also need an install kit, bearings, shims and seals!
Thanks!
Thanks!
