F22C1 at 9000rpm?
Originally Posted by ultimate lurker' date='Feb 21 2005, 09:54 PM
Elistan,
You might be able to run the F22 to 9000 rpm without blowing it up, but if you do it enough (drive it like its an F20C essentially), you will break a rod. Running an F22 to 9000 rpm is roughly equivalent to running an F20C above 10000 rpm (piston speed is equivalent to about 9700 rpm on the F20, but loading is dependent more on piston _acceleration_).
I've talked to a number of Honda engine builders with racing experience (including several who've built race winning World Challenge engines) and they all feel that 8400-8500 rpm in a street car would be the max repeatable safe limit for the F22C, and in racing use where you're spending lots of time near the limiter, it should be more like 8200-8300 rpm.
In order to make it rev, you really only need to do one thing - change the rods/rod bolts. With good rods 9000 rpm would not be a problem, as Honda engines of this stroke length (H22 engines) have reliably revved to 9k+ with aftermarket parts.
SC
SC
Anyways, note he said you could probably do it, but drive it like an F20C and eventually you'll break a rod. obviously the rods in the F22C are different than those in the F20C. I assume they are probably longer, hence the extra .2 liter displacement.
Also note what he said about loading and the pistons.
Actually, the rods are shorter - it's the crank that has the larger radius, given the additional stroke. Just lengthen the rods and you'll have the same stroke, just further away from the crank.
There's all sorts of engine design considerations considering the rod length to stroke ratio that has some sort of bearing on how fast the engine can spin. From what I can understand about the subject based on my readings here, as the rod/stoke ratio becomes smaller (ie, a long stroke with short conrods) the stress on the engine (be that cylinder side-loading force from the piston, or some sort of strain on the rod itself, I dunno) increases.
http://www.hondanews.com/CatID2069?mid=200...141254&mime=asc
For example, the F20C has a stroke of 84.0mm, and a conrod length of 153.0mm. That's a ratio of 1.82mm.
The F22C1 has 90.7mm stroke and 149.65mm rods. That's a 1.64mm ratio.
One quick search says that a 1.65 to 1.80 ratio is ideal, with 1.50 being the absolute minimum.
UL, could you help out my understanding on engine dynamics and explain why the faster revs would more likely lead to conrod failure, rather than something involving the piston directly? Is it simply that the extra distance the rod has to travel, and the therefore higher accelerations is experiences, are too much for the rod material to handle? If so, are there stronger aftermarket rods that could be put in to compensate for this?
Thanks!
Thanks!
FYI
There is a F22C1 installed inplace of a F20C (There is a thread posted on this in S2k Talk). It has been dyno'ed. It made 9K with out any problems (so far). They found that the MY02 ECU dumped in a ton of fuel between 8300 and 9000, so the power dropped off. Next up is fuel tunning.
In short, someone is trying this.
Originally Posted by Elistan' date='Feb 22 2005, 10:53 AM
CrazyPhuD says a friend has been tracking a car like what I'm interested in for 9 months without issue. That's the best datapoint yet, IMO, assuming it's legit.
"Second," eh? So he already blew one? Bummer.
Stratocaster, do you by chance have a link to that thread? Is this the one you're referring to?
https://www.s2ki.com/forums/index.php?showt...dpost&p=4795335
I'm surprised that the 02 ECU put in too much fuel for the 2.2! I was hypothesizing that the known richness of the earlier ECUs would be compensated by the additional displacement and airflow of the larger engine... Hmm.
Also remember the intake and exhaust have not be changed from MY03- to 04+ really. A 2.2L at 8200 rpms will be flowing similar cfm to a 2.0L at 9K....you may run into additional airflow restrictions buy spinning the 2.2L higher....
Thanks!
Thanks!
We've generally found that most Honda engines are capable of handling 400-500 rpm over stock on a regular basis for street driving. However, there are prices to pay. On the regular F20C, exceeding 9000 rpm on any regular basis will cause valve retainer problems (as we've seen on some race cars which were never taken above 9300 rpm and no overrevs). But the bottom end is fine. On K20A2 engines, cars that exceed 8600 rpm under racing conditions will break a rod within a couple of races - we've seen it happen to three separate race teams such that it has become a defacto standard to keep stock rod K-motors under 8500 rpm for racing purposes.
As I said, I think an F22 would live with revs to 9000 rpm, but sooner or later you're going to break something. For street and occasional track use, 8500 rpm is generally accepted as safe. For heavy race use, as I said, we won't exceed 8200 rpm until someone starts beating us, and then we'll do it with much trepidation.
UL
CrazyPhud, in our testing we've found that power tends to flatten off at 8000 rpm on the F22 and stays flat up to about 8400rpm where it starts dropping, so airflow considerations are important.
UL
UL
