F22C1 with 00-03 ecu
#21
Banned
I have a question.
the Mugen ECU does nice gains to the F20C(yes I know an EMS can probabaly gain more, but even UL said the Mugen ECU was damn inpressive)
So, With its remappeping, timing advance, and etc, how would the Mugen ECU wok in a F22C???
I am really curious
Thanks
I am really curious
Thanks
#22
The Mugen ECU works well in the F20C because the stock ECU (especially the 00-01 version) are tuned to use a lot of fuel - more than is optimal for power. The Mugen ECU leans things up a bit - think of the gains 00-01 owners get with a VAFC.
The 00-01 ECU seems to be a good match for the F22C because of that richness - the extra displacement requires that extra fuel.
I'd be worried that a 2.0 liter tuned Mugen ECU would be dangerously lean if used with an F22C engine. But that's just speculation.
#23
ok first off shorter rods would be a decrease in stroke... the shorter the rod the faster the motor can rev. or higher i should say aswell.... look at he F1 motors huge pistons small rods.
2nd reving a motor at a lose of power ofter it hits peaks power in the band ifs pointless if you can shift back into the power band...... so making less then peak power to 11k is pointless .... if peak power id 210whp at 8300 and you drop to 190whp at 9200.... then it would faster to shift in to the rising power band then the dropping..... not sure what races you have entered to think other wise haha but... think about it.
the piston speed at 8200 is the same as 9k.... but that is what i said... i never said that it was safe to rev it to 9k... honestly i do not think anythign will break do to what i have seen... BUT 8600 is the highest i woudl go with out upgrading bolts... the rods and piston will not break at theat piston speeds. and the sleaves can handle mcuh higher loads then that since 9psi is a much larger load then the 2.2 reving to 9k and nobody had problems with sleeve issues....
as for boost, boost has nothing to do with piston speed, which is the main issue here.
and why why would you make a point that the f20 could rev to almost 11000 which is a much higher piston speed then 8600 in the 2.2...... i will bet that they hardware in is the same as stock and the sleeves are also stock since they have zero problems with them. also if tyou have ever seen the stock rods out of thebottom end you would see how they are built and rod flex is not a even a issue in the s2k even under boost.....
also, the rod bolts are the main area of concern regarding the piston speed.
#24
Originally Posted by Wisconsin S2k,Sep 24 2005, 09:33 AM
sure it does. people have taken even the F20C to almost 11,000rpm and made useable power without changing the air flow characteristics through aftermarket parts in the head, etc.
The folks that have mechanically over-revved their engines to approx 10,800 RPM needed new motors. This magical number is where Honda gurantees the engine will come apart. This number came straight from the model engineer.
I accidentally mechanically over-revved my S2000 to approzimately 10,200 RPM without any damage - and I was lucky. I spent the next 20,000 miles checking things like the retainers every 5,000 miles to ensure the engine wasn't slowly coming apart. Luckily the engine is was still running like a champ before I put the car in long-term storage.
Nothing in the F20C is designed to tolerate 11,000 RPM.
#25
Originally Posted by slipstream444,Sep 25 2005, 01:28 PM
Almost 11,000 RPM ... nonsense.
the member I was referring to revs his car to 11,500rpm. however, even with aftermarket parts such as valves, retainers, springs, rods, etc, he still has to "rebuild" parts of the engine every other month.
my point was that he did this without changing the flow characteristics. in other words, the aftermarket parts did not increase the flow coming into the engine. the aftermarket parts allowed him to rev to 11,500rpm, which he does.
#26
#27
My gawd there is a lot of in this thread. Some of us need to take Engine Design 101 before typing in here again.
The head should not be the problem. The F20C head handles 9000rpm so I assume the F22C head should be fine. There are a few different parts but I suspect they are stronger rather than weaker.
Rod length does not affect stroke. It does affect rod angle and sidewall loading.
The F22C has a longer stroke and shorter rod and hence has a geometrically higher piston acceleration and speed at any given RPM.
My input: People around here are always asking for definitives even though we know that this is an imperfect world which can only be measured in terms of probability.
So here's what we know:
Some users have run the F22C to 9K successfully.
Some users have killed F20Cs in normal recommended operating conditions.
All I can conclude from this is that if you run an F22C to 9000rpm the rate of failure (X out of 100) will increase and the MTBF (mean time before failure) will decrease. However as I doubt the sample set will be big enough it will be hard to ever verify this prediction. Buyer beware.
viewmtrp
07-05-2013 06:42 PM
ricecooker1280
19
11-09-2005 09:47 AM
