F22 swap in an ap1,,injector identification
New hear, new s2000 owner and a mechanic , ?,can someone please make this easy , I have an ap1 with an f22 swap, turbo running rc 550 injectors , got the car like that... I want to raise boost and go e85 so hence the injector identity issue, from what I have under stood f20-f22 use different injectors,?,, I have identified my motor as the f22 from a factory stamp that can be viewed looking over the top the motor the question is what injectors to go with ones intended for ap1or ap2 and how do you come to this?,,thanks NeTo
00-05 use the same type injectors, 06+ cars with dbw use different injectors. AP1 or AP2 does not matter.
Looking at your picture I can spot a cable throttle so your engine is 00-05.
Thanks!
[left][QUOTE=flanders;24571708]00-05 use the same type injectors, 06+ cars with dbw use different injectors. AP1 or AP2 does not matter.
Thank you !,, you just verified for me what I need to do,,
gst19psi
04-08-2014 10:23 PM
