F22 Head and Valve cover
With regards to what used to be a traditional PVC on the F20 Valve cover, and is now that horizontal port poking out of the valve cover in the same area. I'm not quite sure what hose I should hook up to that.
Member
I put a F22 MY05 valve cover on MY02. Its the port with the line from the intake manifold that is directly adjacent to it - would be otherwise connected to the PVC line. Not sure if I'm understanding your question correctly.
thought so, just makin sure. My engine removal wasn't well planned out and I'm in the final stages of 'where does this go?'. Mostly lines for the fuel evap system and such which, since this is a track only car, I really shouldn't worry so much about.
That port is the PCV.. hook the line from the intake manifold to it. If your manifold has only one inlet on top, use that. If it has three and a sensor, use the front most inlet.
