F20c rebuild head and block
Is there any one have instruction how to DIY rebuild Head and block Rebuild, im going to attemp to replace my piston rings and valve seals , please let me know thank you.
Your only real option is a service manual. A DIY isn't going to have all the specs and tolerances that you need. You'll most likely need a cylinder head shop for the valve job, guide check/replacement, and resurface.
With a little bit of searching you can find a PDF of the OEM service manual..
Silver_Bullet_S
10-06-2018 01:15 AM
vert2k
03-26-2012 03:16 PM
