F20C Fuel Injector Impedance/Type?
Old 11-13-2002, 05:22 AM
marcucci's Avatar
Default F20C Fuel Injector Impedance/Type?
Do we have high impedance injectors or low impedance P&H, stock? I'm guessing high impedance, since it's what most Hondas run, and I don't recall seeing a resistor anywhere under the hood...
Old 11-13-2002, 07:29 AM
Former Sponsor
Gernby's Avatar
Have you looked at the wiring diagrams in the Helm's manual?
Old 11-13-2002, 09:08 AM
ultimate lurker's Avatar
I'd say high impedance as well. I don't think any Hondas have run low impedance since the early 90's. But, I'm just guessing. You could always throw a multimeter on one of them. Low impedance tend to be in the 2-4 ohm range, high impedance in the 12-16 ohm range if memory serves.
UL
Old 11-13-2002, 12:35 PM
marcucci's Avatar
The '96 H22A IIRC was the last Honda to run P&H with the resistor. If not, then it was '95 (know that one for a fact). Not sure about the F22 and H23 mills.
Greg, don't know about you, but I don't keep my manual up here at work.
Old 11-13-2002, 01:18 PM
Former Sponsor
Gernby's Avatar
I must have left it at home today...
Old 11-13-2002, 02:46 PM
cjb80's Avatar
They are high impedence. You need to run a resistor box to go over 550cc.
Chris
Old 11-18-2002, 06:44 PM
Wildncrazy's Avatar
If anyone has one out or is under the hood soon they can check.
If you have a voltmeter with an ohms setting you can check it. Pull the electrical connector to an injector and measure the resistance.
High impedance would be 12-16 ohms and low impedance 2-4 ohms.
I will check this weekend when I have a little time if no one has before then.
Old 11-20-2002, 05:45 AM
cjb80's Avatar
I'm not lying, I promise.
Old 11-20-2002, 12:06 PM
schwett's Avatar
anyone know how big they are (i'm guessing like 340 to 390), and what the duty cycle tops out at? honda usually runs them to 85% or so iirc....
Old 11-28-2002, 07:30 PM
Wildncrazy's Avatar
AEM says they are high impedence.
RC Engineering has not bothered to return my call or email so I don't know size, but their injector size calculator says we must be in the 410 range.
Quick Reply: F20C Fuel Injector Impedance/Type?
