f20c block in to a 2006 HELP
i havent started on my car yet but i found this pic i do need to change it thanks for the info and help
99-05 on the left and 06-09 on the right
Originally Posted by dmao,May 17 2010, 09:18 AM
I was wondering how yours ran when you had the AP1 crank sensor and wheel, and if you were able to fix it by swapping them for the 06 parts?
Thanks
Originally Posted by rob.ok,May 14 2010, 01:33 PM
Has the head or the block been milled?
I would go back through and make sure that the trimming chain, cam gears, and crank are perfectly aligned at TDC.
It should look like this....
You might have to rotate the crank a bunch of times to get the 2 colored links to match up with TDC.
If that doesn't work then I don't know....
-Rob
-Rob
-Rob
-Rob
Silver_Bullet_S
05-11-2018 06:45 AM
