F20/K20 head?
Old 01-12-2007, 09:54 PM
TitusS2k's Avatar
Default F20/K20 head?
Will people help me understand if this can be done, and the purpose of this particular swap. WHats are the Pros of this setup?? Also i have heard people saying you can do a K swap into the car, and rock the F20 tranny?? Im just wondering!!
Thanks everyone!
Old 01-13-2007, 12:07 AM
jzz30's Avatar
the k head will fit the f20c block but i dont get the advantages as the valves are 1mm smaller, and tuning is also a bitch as there are about 15 maps for every degree of timing that can be changed.
Old 01-13-2007, 06:23 AM
negcamber's Avatar
K20 head has iVTEC, which adds variable timing control (VTC).
Other benefits are plentiful well tested cams. There are also big valve mods available.
There are a couple tuners working to find a way to mate the K20 head to the F20 block.
Old 01-13-2007, 06:54 AM
Slows2k's Avatar
Not easily. The timing chain drive is completely different. The S2000 uses a single gear driven by the chain and cams that are driven off it. The K's directly drive the cams with the chain.
Why you would bother swapping a lower flowing head is beyond me.
Old 01-13-2007, 07:24 AM
SpitfireS's Avatar
In March 1923, in an interview with The New York Times, the British mountaineer George Leigh Mallory was asked why he wanted to climb Mount Everest, and replied, 'Because it's there'.
Old 01-13-2007, 07:50 AM
Otherguy's Avatar
shit if you have money and time go for it
Old 01-13-2007, 08:54 AM
negcamber's Avatar
Does it flow less due to valve size or port size?
Old 01-13-2007, 10:34 PM
ek9k24's Avatar
k heads have much better cam choices ans better manifolds avalible..iam actually trying to make an adaptor plate on the tranny so i can use a full k seris swap that way i can use the extra motor and kpro i have to some use...ive had very good results with past k seris builds..
Old 01-14-2007, 07:41 AM
VAD
VAD's Avatar
The F20 sucks. Pull yours out and ship it to VAD.
Old 01-14-2007, 10:38 AM
slipstream444's Avatar
If that doesn't work, maybe you could try an LS turbo motor swap!
You've got a lot more than a 'tranny adapter' to worry about with a K-series motor.
This type of thread broaches is ugly head every three months or so and thankfully goes away.
Give a year or so sport - if the S2000 survives another model year, it's likely to evolve with a rear drive variant of a K-series motor (along with perhaps a V-6 option). Then you can throw your money at all sorts of K-series candy and brag crazy horsepower numbers to all your buddies.
Unfortunately, Honda won't hang onto the low production F-series motor for much longer. They don't make money on it.
The S2000's F-series motor is, and will be remembered as one of the best piston-driven motors ever produced. The K-series is a pretty darn good motor as well. Rob like.
Quick Reply: F20/K20 head?
