F20 to a f22 motor swap
Then you have a lot of work ahead of you, just to get it to run.
you will need to use these parts off your current AP1 engine:
-Wiring harness
-knock sensor
-flywheel
-complete intake manifold assy with throttle body, and all associtaed hoses connected to it
-Camshafts
-valve cover
-trigger wheel (requires you to remove the head OR oil pan, and then the timing cover)
-crank sensor
-If it were me, I would change the entire cylinder head. the head is not machined for the AIR system and you will have a permanent CEL. You could do an izzy-engineering air-pump-simulator, but if you get a visual check for yearly inspection and someone notices it, you're screwed. The way I see it, with the motor out and the intake off, its a fast job to pull the head. Then you can slip the timing cover off and change the trigger wheel
-Wiring harness
-knock sensor
-flywheel
-Camshafts
-valve cover
-crank sensor
-Wiring harness
-knock sensor
-flywheel
-Camshafts
-valve cover
-crank sensor
-Wiring harness
-knock sensor
-flywheel
-Camshafts
-valve cover
-crank sensor
I have a 2001 S2000 with a bad F20 engine. I have an F22 Engine available.
-I am using the original 2001 year harness.
-Using original knock sensor.
-Using original Flywheel.
-Using complete intake and everything associated.
-DID NOT use original Camshafts. I only swapped the trigger on the back of the intake cam.
-Obviously used original valve cover.
-I am currently in the process of swapping the crank trigger.(Pulling oil pan and timing cover as I do not want to pull the head).
my concern is once I swap the crank trigger what other issues are there.
-Why swap cams? is swapping just the intake cam trigger okay? the 2.2 engine had a trigger (different shape) but no sensor in the valve cover.
-Does the cylinder head have to be changed? I understand the 2.2 head is not machined for the air system. I can live with an engine light. I am just concerned about long term damage or problems arising.
2.2 engine is in the 2001 year model and running very well. I am getting a crankshaft code due to the crankshaft trigger, and secondary air injection code. Crankshaft code will hopefully go away with trigger swap and secondary air injection I am assuming is because of the cylinder head. As I said I can live with an engine light as long as everythig else is safe.
Any further info would be greatly appreciated.
