f20 is dying. need help!
ok, my 01 is going out on me. one of the rings are going bad. i dont want to rebuilt it or rip apart the block.
so i found a f22. its just the block and head. no alternator, intake mani, nothing!
the question is,
1. will all the things i need to go on the f22, can be taken off from the f20 and work without any problems? (alternator, header, intake manifold, etc)
2. i will still have the f20 ecu. will it work without me worrying about emissions? i know that the f22 only goes to 8k, but pushing 9????
3. anything else i need to worry about?
thanks for your input.
the question is,
What year is the F22 from? I know 04-05 longblock will swap right in, but not sure about the 06+. I have an F22 swap in my 01, and all that I changed was the longblock. I recommend at least a VAFC for tuning.
Good read:
https://www.s2ki.com/forums/index.ph...ic=254276&st=0
Good read:
All parts exact fit
There WOULD be a small piece of fuel line that needs to be cut, but since you are using your fuel rail all is good without cutting/modding.
