Extremely annoying noise in rear...
Deff check the axle nut first!
Did you check the spare tire? The little metal tightener on top gets loose and rattles. If you have a loud exhaust check the metal poles that cross each other in the trunk. Mine rattled together.
Is it more of a metal tap or a thump? Thump most likely has to do with suspension / wheels / etc. I had a thump the other day and was missing one of my upper control arm bolts... God knows how that fell out.
I did the axle TSB a while back, but didn't grease the nut. I'll redo that this weekend. I did notice the metal bars touching in the trunk and bent them apart. This is more of a thump, and is definitely coming from under the car. I think it may be a bad shock. I noticed that something is rubbing the inner edge of the rear bumper cover and leaving a burnt-plastic crust on the area being rubbed. I don't see how it would be possible for the rear tire to move back far enough to rub the inner edge of the cover, even with the shock compressed. I'm really confused there. But as I said shock seems kinda likely because I can hear this noise sometimes when someone sits down in the pass. seat while the E-brake is set while sitting still. I'm running out of patience as it aggravates me wondering if some part of the suspension assembly is going to come apart while I'm hustling down the switchbacks during my daily commute...
Billman250 - I don't know where your getting your information but your NEVER supposed use any type of grease on an axle nut, its always engine oil and its applied to the threads as well as the shoulder of the nut. If you lubricate the fasteners shoulder and not the threads your always going to get a fluctuation in torque measurement regardless, especially if you use wheel bearing grease...
- I would never question Billman, of all people
- Even the Honda TSB states the use of grease: https://www.s2ki.com/s2000/gallery/p...499__file__med
I definitely had a click on my rear every now and then and the axle nut grease and retorque to 220 lb-ft fixed it right up.
I believe you don't apply grease to threads because it'll give an erroneous torque reading.
I surly dont get it from this website, I give it.
GREASE THE FACE, not the threads, and dont listen to turboviper. Engine oil will result in over-torque, and breaking of the axle during launch.
I have performed over 600 axle nut "tsbs"...how bout you?
Maybe your :tip wink: hat is sitting to low.
