Exhaust Install Q
Exhaust Install Q
I'm installing my HKS exhaust and I am wondering if I need a gasket between the Cat and exhaust? THe stock exhaust doesn't seem to have anything between the cat and exhaust.
From memory, and it's been a couple years since I did an install, but I've done several, I thought there was a gasket with the OEM. I've done Invidia and HKS a few times and they came with a new gasket. If they didn't come with one I'd use the OEM if nothing else.
Yea, the stock one has a little ring that is probably still stuck to the stock exhaust.
Do you need a gasket? I don't know but I sandwiched the little ring in there when I installed the Invidia in my MY01.
Thanks guys, I ended up going to NAPA and getting something close and modifying the screw holes to work.
One question though, on another part of the piping there was a little bit of water that came out after I tested out the exhaust and checked for leaks. Is this okay?
Originally Posted by xviper,Jan 15 2006, 03:13 PM
You need one of these:
typically you can hear an exhaust leak. another way is to feel with your hands with the motor running. you will feel the exhaust spewing out.
Note: do not attempt while driving....
