Exhaust gasket?
Exhaust gasket?
What is the parts number for oem exhaust gasket?
18302-SP0-003 is what I found on Bernardiparts.com but when I went to pick one up at the daler, it looks like a ... thin circular ring... not the kinda gasket I expected... more like a triangular shaped thin gasket that get sadnwiched in between the catback and the catalytic conv...
I'm trying to install ASM Ti single 70mm here and can't find a damn gasket...
help please.
help please.
Here is a helpful site for finding Honda part numbers:
http://www.slhondaparts.com/browse.asp?Model=S2000
you can only use the metal o ring gsket if you have oem exhaust if you have aftermarket exhaust you have to use the triangle gasket. you also can make one like i did.
I had no problem taking my aftermarket exhaust into an autozone and asking to find a gasket to match it. They have a big bin of different gaskets, and I just went through it until I found one that matched.
