Exhaust bolt problem
I just ordered a new exhaust and went to remove my stock. There was quite a bit of corrosion on the bolts from the Cat. I used Liquid Wrench on the bolts a few times and went to remove them. Instead of removing them I think I succesfully stripped them.
is there any way to fix this without having to go to an exhaust shop? And how much would having these bolts removed run me?
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
I ran into this problem when I was taking my cat off. I broke the nut off, which is fine. If you can't get them off you may have to just get a grinder and cut them off.
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I stripped two bolts off.....not I biggie at all. Just pounded the stud out and used bolts.....
What do you mean stripped?
Get a dremel and a cutoff wheel, cut the nut off, and pound the stud out.....
I guess i was confusing, no supprise!
I stripped the NUT head so my wrench wont turn the nut to get it off. The bolt threads are fine because the nut didnt even move before i destroyed it. Whats involved in breaking it off?
I dont have a grinder or a dremel to cut the nut off so i guess i am stuck with going somewhere to have them do it for me?
make sure you're wearing dam safety glasses!! i ran into the same thing except snapped my bolt heads off...just made up some sort of the same thing at the hardware store
TokeMadBowls420
09-26-2003 03:51 PM
