Exhaust bolt COMPLETELY stripped
I'm sorry, not the bolts... The nuts are stripped...
I may have caused a problem though... I drilled a hole into the center of the bolt thinking I could just break the bolt and the nut would come off (don't ask me why, I was frustrated and not thinking straight)... So now did I just screw myself over? Do I have to use the bolts that are on the cat or can I just the new ones that came with my invidia exhaust?
Originally Posted by S2K:-),Apr 4 2006, 05:01 PM
See that's my problem... I only have the back jacked up with enough room for me to fit under there. I don't have a plasma cutter either. I'm guessing I just have to go to the muffler shop tomorrow and have them do it.
![eek.gif](https://www.s2ki.com/forums/images/smilies/eek.gif)
![eek3.gif](https://www.s2ki.com/forums/images/smilies/eek3.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Well if the shop is gunna rip me off I'll just go to my friends shop... He has a lift and he'd probably just let me do it (but if I only have to pay these guys a little bit i figure what the heck, i might as well just have them do it)
I highly recommend using the craftsman bolt out kit. It is specifically designed for stripped bolt heads. I've used it numerous times and it has worked every single time. What you do is bang on the closest fitting socket head and it will create its own groove and let you use enough torque to remove the bolt.
I believe the whole kit runs around $30. It is really worth it.
At this point, if you wish to continue on your own, take the whole cat off when you can. Spray the front nuts and spring bolts too. Once off, you can work better at getting the remainder of the bolts out of the cat.
I'm not sure that any aftermarket exhaust will come with the nuts and bolts for the rear of the cat. They may expect you to use the stock ones.
A "bolt out" may not help you if the nuts are really rounded off. Once you get the nuts off, the bolts may be OK and you just need to get new nuts.
If the bolts are buggered, the bolt part is pressed into the cat just like the wheel studs are on your hubs. You have to pound them suckers out of there. Of course, heating them with a torch will help but if you're careful and persistent, you can be beat them out or drill them out. Then you can go get nuts, bolts, washers and lock washers of the same size and length and use those. Unless your cat back actually supplied them.
Be careful not to break the wires for the O2 sensor when you take the cat off. Any way you look at it, from this point on, it's going to get a lot worse before it gets better. Good luck!
ps. Can I assume that when you say the nuts are "stripped" that you mean they are rounded off so bad the socket no longer grabs them? And you can't turn them?
And I'm taking this to my friends shop today becaues he might do it for free and if not I will DEFINANTLY come home and try that...
