Even more questions about the VAFC
Old 01-14-2002, 04:27 AM
marcucci's Avatar
Regarding altitude: Shouldn't matter, since the ECU, I'm almost positive, has an atmospheric pressure sensor on board. It should be compensating for altitude changes and adjust fuel accordingly.
Good question: Does the V-AFC monitor atmospheric temp? It has no way of knowing it from the ECU. Since the AFC "spoofs" the MAP sensor, I would think it would need atmosphere as a reference, otherwise it would send the wrong signal. Maybe it skews the signal it reads xx% based on the correction (and doesn't care what the absolute value is).
Old 01-14-2002, 05:39 AM
airsport's Avatar
On any non-turbo/supercharged engine as altitude or temperature increases power output decreases.
Old 02-14-2002, 09:44 AM
Kwando's Avatar
Milo i know you hace tweeked your settings a little bit, do you notice a difference now? I have my VAFC on order and want some base line settings.
BTW who did you take the car to?
Old 02-15-2002, 03:45 PM
Milo's Avatar
I noticed a definite difference. I beat your friends S2000 w/ tanabe exhaust, vafc, and it's ported and polished.
I originally took it to Action Turbo's but it looks like they went out of business. Can't imagine why They did nothing for me. From now on, I'll do any tuning myself, that seems like the only way I can be sure the job is done. Whether it's done right or not, now that's a different matter
Old 02-15-2002, 05:43 PM
josh3io's Avatar
alititude has huge difference on the car's performance. I went for a day trip up to Yosemite, and at the top of the mountains VTEC wasn't engaging until >7krpm. I assume this means the VAFC would need to be tuned differently for those high altitudes.
Old 02-16-2002, 08:13 AM
airsport's Avatar
[QUOTE]Originally posted by josh3io
[B]alititude has huge difference on the car's performance.
Old 02-16-2002, 08:31 AM
Prolene's Avatar
Originally posted by turbo_pwr
I would think that what would matter is that your settings would need to be changed at sea level than at the higher attitude.
I think the stock ecu compensates for altitude, since there is an altitude sensor. Wheter the compensation would help the car run better or worse in regards to power, I don't know. I wonder if VAFC not being tuned for a particular altitude would lose power, but perhaps still stay better than stock, or what?
'Plug and play' ecus, i.e. Mugen, Spoon, although more expensive, seems like a nice way to go, if indeed these ecus take all parameters into consideration in the maximizing power effort.
Old 02-16-2002, 04:41 PM
Kwando's Avatar
I just got my dyno at PFI in Ft Collins. It is surprisingly VERY low. I got only 179.2 rwhp. I will post the details in a new thread later. What's is wrong with my car? Or is there?
ryanboy
09-22-2008 07:35 AM
Kory with an AP1
08-28-2008 04:49 AM
SC-SUZUKA
01-07-2003 07:52 PM
yf69
01-12-2002 06:37 AM
Quick Reply: Even more questions about the VAFC
