EPS light problem
Old 07-19-2008, 05:11 PM
NFRs2000NYC's Avatar
Originally Posted by Togobox,Jul 19 2008, 06:44 PM
2003 under dash #5 7.5 amp fuse name: Back up light/instrument light
. component or circuit protected: back up lights ,convertible to control
unit , eps control unit. gauge assembley, keyless door lock control unit.
If any of above component is working, i won't worry about that fuse,and i've looking up the the main EPS fuse on diff. model yrs they are all 70amps (under hood). did you check your fuse box cover to see how many amps it should be before you replace it?and if the EPS light is not on, i don't think there are any codes stored. so don't waste your time if the EPS light is not on unless you don't have any assist.
i will check again to see if you can jump any connectors to get EPS code
, i don't see any info for that so far.
Thats the thing...the EPS light IS on, however, when the car is standing still, I can turn the steering wheel with ONE wrist, without any struggle.
Old 07-19-2008, 06:22 PM
Togobox's Avatar
oh sorry , i thought your light is off. Try to jump the DLC #1 brown (service check input) and #12 Black (ground) , turn on the car it should give you flash code. Count long and short flashes, long flashes is the first digit, short flashes is the second digit. then will go from there....
Old 07-20-2008, 02:43 AM
Ok, so it's not pin #4 and pin #9?
You are saying...
1)Jump pin #1 and pin #12
2)Turn the car to ACCII
3)Watch the EPS light flashes
4)Record them and post back?
Also, just to make sure we are on the same page, which way are you counting? (which pin is #1 and which is #12)
Old 07-20-2008, 11:53 AM
s2kBryan916's Avatar
My advice would be use pin four and nine. Flash the code(s) and go from there.
DLC pin number is standard, refer to the picture of the connector if you need
help.http://www.k-series.com/tech_detail.php?Tech_ID=CEL
Old 07-20-2008, 01:54 PM
Togobox's Avatar
i used non-SAE ternimal number used in service manual.
if you not sure which pin is which, look into the color of the wires. jump Brown and Black.
Old 07-21-2008, 02:09 AM
SenderGreen's Avatar
It is PIN 4 to PIN 9 on the DLC.
There is a footnote in the first post of the Ultimate Check Engine Light thread.
https://www.s2ki.com/forums/index.php?showtopic=378792
help. http://www.k-series.com/tech_detail.php?Tech_ID=CEL
Here's what I got saved in a text file. I think it's still accurate.
The OBD-II specification provides for a standarized hardware interface
Old 07-21-2008, 03:05 AM
[QUOTE=Togobox,Jul 20 2008, 01:54 PM] i used non-SAE ternimal number used in service manual.
Old 07-21-2008, 03:08 AM
Follow his link, it'll work. Good pictures, same procedure for the S2000. Works for normal CEL DTC's as well as ABS, SRS, EPS DTC's. All of these DTC's can also be cleared without the dealership at least up to MY03.
BA4toAP1
06-10-2021 05:50 PM
Dembo
08-16-2014 07:03 AM
Ap1Luis
04-15-2012 08:26 PM
hass2k
11-28-2005 03:43 AM
babYspYda
06-18-2003 06:48 PM
Quick Reply: EPS light problem
