an EPS light comes on in my cluster....can anyone help
whats up guys...my EPS light comes up on my cluster in yellow...can anyone tell me what this is?
thank you
thank you
EPS stands for Electric Power Steering. Means something in your power steering system is not as it should be. There will be a diagnostic trouble code a dealer can read. You could try disconnecting the battery for a while and re-connecting but that is unlikely to help. There is also a centering procedure in the Helms shop manual you could try, again only if you're a billion miles from a dealer.
if the car sits and is running for a while this happens ie 15-20 mins, as soon as you turn the wheel it will go away, if your car sits for long periods this happens to.
MAtt
MAtt
so if the light is on and i drive the car..it would not be a problem...i would not damage anything? the light comes on and off like pierce man says..but it comes one when iam also driving?..
