EPS light on
Old 05-07-2011, 05:36 AM
Ap1Luis's Avatar
Default EPS light on
i had just got done washing my car.. everything was fine. I went to the movies parked it and came out and this light was on. i didnt think it was a big deal so just went home. in the morning everything was fine, but then i parked it and once againn the light came on. repeat this for like 3 days (it would do fine in the morning). and now it stays on.. what could this be? lol
Old 05-07-2011, 06:34 AM
blkstallion's Avatar
Are you experiencing steering problems or the light is just on? From what I gathered in the past from a few s2k owners, If you are not experiencing any driving issues and the only thing that is out of the ordinary is that EPS light, than you would have to stay at a constant speed of 55mph or a certain amount of miles before it comes off.
Old 05-08-2011, 09:40 AM
Ap1Luis's Avatar
yes i have no power steering ..i found a relay on it but its fine so not really sure on what i should check on next.
Old 05-08-2011, 09:58 AM
rsx>s2k's Avatar
mine just went on last night SMH
and my speedo doesnt work
and its alittle hard to steer
Old 05-08-2011, 06:44 PM
First things first, check the fuses in the EPS Module.
Old 05-09-2011, 02:59 PM
OneSilverS2k's Avatar
Check for any corrosion. Also see if there is a voltage drop across the connector. Something may be stealing the load, i.e bad connection, or corrosion.
Old 05-10-2011, 01:45 PM
rsx>s2k's Avatar
everything works on the cluster but the speed
i think it the speed senser
Old 05-12-2011, 10:27 AM
Ap1Luis's Avatar
fuses are good.
where should i check
Old 05-22-2011, 08:33 PM
Ap1Luis's Avatar
bump..
Old 05-23-2011, 07:53 AM
Stratocaster's Avatar
Since the speedo is also not working, you need to troubleshoot further up stream. The VSS is located on the back 1/2 of the drivers side of the transmission, just behind the clutch slave cylinder. Check that connection. It is directly connected to the ECU by way of the engine harness and dash cluster. The dash cluster then steps down the VSS signal to a lower rate and then feeds the EPS, soft top controller and one other I can't remember. So you problem is not the EPS, that is just a symptom as is the speedo reading 0.
Quick Reply: EPS light on
