EPS light is on
Banned
EPS light is on
I relocated my fuse box and my eps light is on. What should I do to trouble shoot the issue? Everything looks good from what i can see.
Try driving around the block and seeing if it turns off. Seriously ... EPS needs a valid speed signal, so that can sometimes be the issue.
Other than that, I guess pull the code and see what it says.
Banned
I fixed. Pretty stupid mistake. I plugged the harness's in the wrong sides. For anyone who is doing a fuse box relocation make sure you put the plugs on the eps on the right side
Other then that my abs light is on. It came on once I put my oem wheels and tires back on... Before the relocation.
