eps- installed new rack but eps not working...
i lost my helms manual... is there a trick to resetting the EPS to work? I pulled the fuse for about 2 minutes and also disconnected the battery for 2 minutes... (not at the same time)....
any other tricks? i broke the old rack on the track hitting another car... so I got a "used" rack that is working to turn the car but now Power steering...
anyone? thanks.
anyone? thanks.
Administrator
there is a process to reset the eps and to pull the codes. My helms is at my shop. There are pdf's floating around.
Are you sure you didn't swap the power wires on the controller? It has 2 connectors that are the same and are easy to swap.
-Ry
-Ry
