EPS Help- Resolved
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Memorize Torque Sensor Neutral Position:
With the wheels on the ground:
-Ignition off: Short the DTC connector. Set the steering wheel 45deg to the left.
-Turn the ignition switch to ON. DO NOT start the engine.
-The EPS indicator will go on and then off.
-When the indicator goes off, within 4 seconds, turn the wheel back to straight ahead and release it.
-The indicator will come back on.
-Within 4 seconds turn the wheel back 45deg left and release it.
-The indicator will turn off.
-Within 4 seconds turn the wheel to straight ahead and release it.
-The indicator will blink twice 4 seconds later, and then three times 5 seconds later and the turn off.
-Turn off the ignition.
-Done.
If the indicator is just blinking over and over when you turn the ignition on, the steering wheel is not in the neutral position. You have to try and find it, and when the sequence starts, turn the wheel back to straight ahead within the first 4 second interval, and then continue with the sequence like the NP was straight ahead to begin with.
FWIW, I think my problem was just a trashy Torque Sensor. It does it all the time when it gets cold. I never was able to tear it apart, but if anyone has a dead spare I will pay shipping so I can crack it open. Between the EPS and the TS that's the only two culprits I can see at this point.
-Done.
Korwen (04-03-2022)
