EPS codes
EPS codes
Did a search and came up with nothing. I pulled the codes from the EPS light on the dash and got 2 - 1. Anyone know what that means?
"A problem with the voltage for IG1."
1. Check the INSTRUMENT LIGHT fuse (7.5 amp) in the under-dash fuse box. (If bad, most IP indicators will be out.)
2. Disconnect EPS control unit (next to battery) 14-pin connector. Turn key on and check for battery voltage between Pin 1 and ground. If yes, check control unit connectors; if no, check wiring up to 14-pin connector.
BOB'5
06-02-2005 02:49 AM
