Engines knocking......
Knowing that water gets the combustion camber sparkling clean, I decided to steam clean the inside of the motor. I drained the oil from the car, put on a new oil filter and filled up the car with 5 quarts of high quality distilled water. I figured the water would remove any crud and grime left in the motor and make everything shiny new. I drove the car for about 45 minutes, in that, I wanted to heat up the water so it would power through any grime. I got home and changed out the polluted water and oil filter. I filled it up with 5 quarts of Mobil 1 and started it up. It knocked so loud my neighbor came over and ask me if I had installed a diesel in the car. Can someone help me? Why is my car knocking so loud? Did I remove too much grime from inside the engine?
It's just like this story about the failed port and polish attempt by sucking 25 lbs of sand thru a running engine. Oldie but a goodie
http://carscoop.blogspot.com/2008/05/guy-a...ormance-by.html
