Engine warning lights
Old 08-29-2004, 12:19 PM
Mr. Francesco's Avatar
Originally Posted by xviper,Aug 29 2004, 02:45 PM
You don't have to disconnect the battery to reset the ECU. This will require you to have the radio code and to reprogram all your stations. Pulling the "BACK UP" fuse under the dash will accomplish the same thing without giving your radio an aneurism.
your the best xviper.
"backup" fuse under the dash. is i just a dissconnect and reconnect thing, or will i have to pull it for a few minutes?
Old 08-29-2004, 12:26 PM
revhi's Avatar
Originally Posted by BRAHMABULL421,Aug 27 2004, 08:04 PM
is this true?? i have a cel light on in my01...because i installed a air/fuel ratio meter...does anybody know if it affects the v-tec??? and how do we find out if our v-tec is working properly??( without driving it of course, if its possible..)
an air fuel gauge shouldnt cause a check engine light.
Old 08-29-2004, 02:25 PM
xviper's Avatar
30 seconds is all you need. Look here for the whole deal:
https://www.s2ki.com/forums/index.php?showtopic=183490
Old 08-29-2004, 05:26 PM
mikegarrison's Avatar
Dave, you probably should add the "relearn engine idle" sequence to those instructions. The Helm manual is very specific about doing that procedure after an ECU reset.
Old 08-29-2004, 05:49 PM
xviper's Avatar
I suppose if there was a problem with the idle before, then this would be a good idea. On none of the cars (my own included) where I've pulled the fuse, I've never done this and the idle afterwards is pretty normal.
Old 08-29-2004, 05:51 PM
read and understood. can't wait to use it this week before i drive my car home...thanks again
Old 08-29-2004, 10:15 PM
Nik
Banned
Nik's Avatar
i unplugged one of the ECU connectors and then put it back. The car wouldn't start, then started and wouldn't idle right. I unplugged the battery, plugged it back and the car was fine.
Old 08-30-2004, 06:30 AM
xviper's Avatar
Why in the world would you go to the trouble of exposing the ECU (removing the kick-panel) and unplugging any of the connectors? Even with the ignition off, the ECU still gets power. Unplugging any connector only serves to confuse the hell out of the ECU. It's like disconnecting power to part of your brain, then reconnecting it and hoping that your whole brain works normal again.
Unless you are doing some major ECU wire tapping (like in a F.I. installation), disconnecting the battery is not necessary. To do a regular ECU reset only requires pulling the "BACK UP" fuse for a few seconds.
msafountain
02-17-2011 12:01 AM
tadao916
03-02-2009 04:47 PM
lamvu
08-20-2006 01:32 PM
DannyInKorea
02-16-2006 09:32 AM
mikegarrison
16
07-31-2004 05:43 PM
Quick Reply: Engine warning lights
