Engine/ Transmission bolt pattern specs
I need the measurements of the transmission bellhousing bolt pattern, or the back of the engine measurements where the tranny bolts on. Been searching for it, but cant find it. We need it to make a adapter plate, and will save the machine shop some time knowing the exact specs of each bolt hole in relation to the center of the crank. Thanks!
Considering someone will give you the measurement, will you trust?
It's a specialty machine shop job, you can't mess around.
I think you need to find a friend who has a spare and accurately measure the pattern.
Norccer
08-01-2018 01:08 PM
