Engine ticking, shavings in oil?
That oil leak looks to be from the crappy hondabond job the previous owner did. I would be concerned that someone so careless was in there messing around and why. I do hear a faint noise, that could be rod knock, but it doesn't seem too different than the "normal noise" some others experience. You will need to drop the pan to fix that leak, when you do that you will get a good peak at what is inside the pan, if you have shavings you have problems.
There were no signs of oil leaking from the oil filter when I checked before I replaced it. I will go ahead and buy some new vtec solenoid gaskets to see if that fixes the leak. The black shavings were hard. It is hard to tell whether it's a tick or a knock, but there's no knocking sound at all when driving which is confusing me.
